Page 216 of 229 FirstFirst ... 116166206214215216217218226 ... LastLast
Results 2,151 to 2,160 of 2290
  1. #2151
    blackpool
    3,415
    Quote Originally Posted by NovalutionGSi View Post
    No one likes a show off...
    I draw the line at it being around 0 and having to lay on the floor under the Nova... I may like it... but not to get a chill in my bones... i'm getting old now.
    Iam feeling it now too at my age.
  2. #2152
    Norwich
    5,659
    So I tried much harder to just spend a few hours a week in garage, which I mostly achieved. Progress is slow but progress none the less.
    Put the passenger side seat rails in. No mounting brackets just yet as I need to make/modify an elise passenger frame first and get another seat!
    Put this tube in connecting bulkhead to front rails to hopefully aid in deflecting any head ons away from my feet!
    Replaced the bits of wood spacing out the A pillars both sides with some little tubes. I?ve got some tidying up to do on shell when it?s next off the frame then this can all be strengthened and boxed in. For now, the tubes help with locating everything.
  3. #2153
    Norwich
    5,659
    I started doing some templating for the bulkhead around my feet. Took forever tweaking it but happy how it all turned out. I also made a start on the frame for the tunnel.
  4. #2154
    Norwich
    5,659
    The sides of the tunnel will be removable, top probably will be fixed, undecided yet.
  5. #2155
    brotton , saltburn by the sea
    1,877
    Looks f'ing mint. One question though, what do you gain by the front coilovers been slightly layed over like that. Great work btw
  6. #2156
    Norwich
    5,659
    Default Spaceframed SR20DET RWD Nova
    Thanks!
    So the geometry is based upon 200sx S14 stock geo and shock tower position, angle etc, but with them pulled inbound for more camber in the stock position (and to tuck inside the inner wings) and up to give more shock travel as I will be pretty low. Also helped to keep the camber sensible for moving so far inboard. I think in standard camber plate position is around 3.5deg. The run a fair amount of castor as standard c6-7deg I think which is typical on a lot of rwd stuff. I moved the engine and subframe back an inch (from memory) and plan to pull the wheel back forward by that again with adjustable lower arms and tension rods. If its too much castor I have a lot of adjustment in the turrets.
    Hard to tell I know from the pics, but looking back at notes it was 35mm in and 25mm up.
    And you can see how in the last pic the wheels are yet to be moved forward, which will induce more castor, which I can always take some back out again on the turrets but spinning the mount holes.
  7. #2157
    Norwich
    5,659
    Assuming that was what you were referring to!
  8. #2158
    1,877
    Yes thats it mate that explains it
  9. #2159
    Jul 2002
    8,107
    That just looks sexy!
  10. #2160
    Aug 2007
    Lelystad, NL
    1,108
    Stunning work as always. Love it.
