Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Removing cam
    Jan 2004
    Yeovil, Zummerzet Fixing: 1650 Sport Wants: A 1.6 8v supercharged
    3,730
    Default Removing cam
    im trying to remove my cam from the cam case, do i need a special tool? PS. lost my haynes
    Senior User Club Member
    Sep 2004
    swindon
    7,906
    you need a special tool or remove the cam houseing which would need to have the head gasket done afterwords.
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    dont forget to undo the lock plate in the dizzy end
    Jan 2004
    3,730
    Quote Originally Posted by chunny
    engine is in pieces anyway. looks like i need a 19mm spanner but all of mine are for fat.
    Quote Originally Posted by Stuart
    Done
    Nov 1999
    35,414
    18 Post(s)
    then pull the bitch out (aslong as the fuel pump is out too)
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Aye, remove the sprocket then tap the mofo out towards the dizzy.
    Jan 2004
    3,730
    that be where i is going wrong. the sprocket is still attached to the cam and im trying to pull it out the sprocket way. I can't get the sproket undone as all my tool that might do the job are to fat to fit between the lobes.
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Lock something through the sprocket holes to stop it turning.
    Jan 2004
    3,730
    cheers, being really slow today.
  10. #10
    Nov 1999
    35,414
    18 Post(s)
    or put a spanner on the hex that most cams have....
