Guys, need some help, doing a project car, just starting to strip the interior so i can change the wiring loom, i cant get the steering wheel off for some reason, any ideas or is it something special i need to do rather than brute force?!
Steering wheel puller is the best tool, but if you don't fancy shelling out ~?10 on a tool you'll probably only use once or twice, you ought to be able to lever it off with a large screwdriver and much pulling on the wheel. Leave the nut on the end of the thread if you do it that way though....
"It'll be done when its done"
Spot on cheers for that, think i'll have to go for a tool, i'll see if i can borrow one, i've already tried levering it off...
yea i found that the hard way and a broken nose later
