Oil Cap - perfect for painting - ?5
Rocker Cover - perfect for polishing/powdercoating - ?20
Sump - oil pick up pipe if req'd - Excellent condition - ?10
Block - Excellent condition - just had professional hone - ?40
Cylinder Head - Excellent condition - fully stripped for inspection but all valves/lifters etc supplied and in perfect order - ?30
16v header tank - twin inlet at the top - ?10
Exhaust manifold and lambda sensor - no down pipe ?10
Flywheel & used clutch if reg'd - excelent working order - ?20
Inlet manifold - Top and Bottom parts - ideal for Mantzel etc - ?25
Fuel rail and injectors - excellent working order - ?15
Throttle body - excellent condition - just been cleaned - ?15
EGR Valve - only a couple of months use - like new ?15
Brand new gasket set - ?30
Any other bits you need send me a PM and I'll see if I've got them!!
