Lol, but then the wires wouldn't be Gm colour codedOriginally Posted by Stuart
Novatracket-Theres plenty of people on the MS forums that are using MS, even ones they've built thereself.
Old XE track car
ok just saying what iv been told and seen throught differant companys.
every company has problems... and MS is a DIY thing so wont have quite the same quality control that others might..... i can be a cocky git and say that the MS i built will not fail on soldering problems... the components might fail but tahts down to poor design on the MS peoples part.
How mappable are these MS ECU's though. I wouldt buiy TB's unless I could get the most out of them possible..
(says me still overfueling 2 years down the line )
With a wideband lambda setup, apparently its quite straightforward to get a good-ish fuel/spark map, once you've worked out initial setup values etc.
I can't see it being too difficult for someone used to mapping emerald/mbe using MS tune program and fine tuning the map.
It was something i was considering, but i dont really think i could have my car off the road, whilst i was sorting the loom,basic map etc, as its a everyday runner.
Old XE track car
actually down to the open sourceness of the MS setup/software and electronics you actually have more control over most stuff than say a DTA etc......
Depends who from & on who built it.Originally Posted by novatracker
There are reputable sellers of the stuff & done correctly you can achieve really good results with it.
By its nature it is for technically minded people that have the time to tinker with it & are strapped for cash, hence not using Autronic.
