Results 1 to 3 of 3
Thread: brakelight electrics
    Senior Member
    Feb 2001
    4,624
    Default brakelight electrics
    After fitting my SR speedo(properly this time...) I fitted the shroud and wheel back in place, I have found out that my near side driving lamp does not wish to work,neither does my number plate lamp or my fog light,Ive tried new bulbs and Ive tried new fuses,any ideas what this is?-could it be a low battery as I havent driven it for a while?-the stereo wipers and all that still work,Im getting confused as to what it could be now,any ideas?
    Senior Member
    Feb 2001
    4,624
    Default RE: brakelight electrics
    okay u maye have disturbed an earth wire down by the bottom ov the gearbox check that
    sumtimes theres a earth leading there for the nearside light and shit
    it may just be a coincedince though
    Senior Member
    Feb 2001
    4,624
    ok I will give that a check,its been worrying me for a few days now, not knowing what was causing the problem. To fit the SR speedo I had to disconnect it from the gear box, to give me some length to work with, it might have been this that caused it,thanx.
