Results 1 to 5 of 5
Thread: Need Techie Advice!!!!a.s.a.p.
    Senior Member
    Feb 2001
    4,624
    Default Need Techie Advice!!!!a.s.a.p.
    I've Just put a Kreg Gsi Engine And Box in my Greg Gte.
    But the Problem it has is that we cant find reverse and 5th in the car at first we thought it might have a 4 speed box but we went to Skurrays and they said that they dont make an F13 Box in a 4 speed! So have you got any clues as of what to do cause it has been to the local Garage and they reckon it might be a box out of another car any advice or suggestions would be very Appreciated!
    And this Engine is supposedly superchipped but still has a rev limiter, i thought the chip took the rev limiter out?
    Senior Member
    Feb 2001
    4,624
    Default RE: Need Techie Advice!!!!a.s.a.p.
    As far as I know a chip just moves the rev limiter and I had the same prob when I put a new box in mine all u should have to do is line the gears up properly
    Senior Member
    Feb 2001
    4,624
    Sounds like the gear linkage needs adjusting, Ste (techy) might be able to help you on this one.
    Senior Member
    Feb 2001
    4,624
    the chip raises the limit 500rpm
    as for the gear linkage try selecting the gears manualy from by the 'box with your hands
    Senior Member
    Feb 2001
    4,624
    i always find that its best to set it up in reverse
