how low can you drop a nova on 15's and still be able to have people sitting in the back
as low as you want, try taking the springs out!!
About -60 is the max but you still may have slight problems with passengers. If you fit coilovers lower -70 or -90 not very practical and you probably won't get away with any passengers. I know people claim to have gone lower but not if you still want to use the car day-day.
weld the axels to the chassis very firm ride me thinks
as ive said many times before,ive got 15s 195/45 rubber,shortened jamex shox,-80 front,-110 rear,i sorted the arches out myself with a big mallet and a peice of wood,pushed the lip up and knocked the arche out on one side(due to one the build quality of them)both are now equal.with 4 peeps in car u get no scrubage.
novaparts do you sit on the road?? feck thats low. seeing as there is only 120mm of clearence according to haynes. did you hammer the inside of the arch too? wouldnt that affect the shock??
grayhem du sueys car is the lowest i have seen looks like hes cut his front arches back to clear on full lock. i have about 70/75 on the front know and 70 definate on the back but this is quite hard
my mate did take his back ones out and lowerd the front!
it was low as fuck and he drove it like that for 4 months!
i have heard that is you take ur drum off take it to a garage then they can skim it for ya and then you dont have to roll your arches as much
not sure if this is true but could be worth an investigaton
