I have been told that the best size alloys to get are 6.5x16 but I can only find 7x16. Would these fit and would I need to do any arch mods?????
Depending on whether your car has been lowered or not, they should fit fine. Make sure you get wheels with the correct offset (im not sure whats best myself). Also roll, cut, or fold the inner lip on the rear arches to give you that little bit extra clearance. Good luck
Jim
No they don't i have a set of 16" kosei snipers on my nova with a 45mm offset and i had to get the arch lips rolled. The wheels also rubbed in the inside when i went around corners. However i put a set of spax lowering springs and gas shocks in which stopped the wheels rubbing altogether.
