Results 1 to 5 of 5
Thread: URGENT HELP NEEDED! (Hub / disc / driveshaft loose???)
    Aug 2004
    1,013
    Default URGENT HELP NEEDED! (Hub / disc / driveshaft loose???)
    Right, just taken n/s front wheel off to lower the ride height slightly(coilovers), and if I hold the disc in my hand and wobble it - it seems worryingly loose!
    The disc itself is tight on the hub- but the CV joint area seems to be the point of most play - where the hub meets the shaft.
    How do I tighten this?
    Is it safe to drive? (guess not!)
    Similar experiences?
    PLEASE HELP!
    Rob.
    Jun 2002
    Cleveleys, Lancashire
    4,104
    sounds like the main driveshaft nut isnt tight
    Sep 2004
    Scotland
    228
    sound a bit like u have play on ur wheelbearing. do u get a "whine" of that wheel when drivin it. Could be a wheel bearin?
    Aug 2004
    1,013
    After consulting the good old Haynes manual, I agree that the driveshaft nut isn't fully tight.
    Don't think its a wheel bearing - certainly no whining noises.
    Will hopefully sort it out tomorrow!
    Thanks for the advice.
    Rob.
    Jan 2005
    Hull
    2,990
    disc is attatched to drive flange which is pressed into the bearing. the drive shaft just slides into the drive flange, so if the drive flage is loose tightening the driveshaft nut probably wont do anything, as its most likely that the wheel bearing has collapsed, they dont allways make a noise when they go, i've known a few to just fall apart without audible warning.
