How much does a proper ICE install cost??
Can anybody do me one?
Like with fibra glass or whatever?
The proper type like show cars have ...cheap!?
Wanna put 3 12's in?! (I got all the stuff)
Also what is the best stealth shelf on the market?
the actual install itself is cheap..ish, the dear part comes when u start 2 put in the subs amp etc, make a few designs and then go to ur local saw mill and ask them 2 supply the wood, they will evn cut it 2 size for u if u ask
Ballsy
mmmmm same shit different Day
Shall I Have 2 subs or 3 ?? 12"s
If I get 2x12's then just get a box which already has the correct cubic capacity from a shop for ?80, already carpeted.
then I easily take it out when I wanna go down to Santa Pod for the 1/4 mile racing!
if 3x12's then need a custom install, never get that thing out!!!!
HOE MUCH DIFFERERNCE WOULD ONE SUB ACTUALLY MAKE IN THE NOVA??
2 or 3, all running off the one BIG-UP amp!
you say you want one like show cars have.
a proper one can be VERY VERY VERY expensive if you get a shop to do it. otherwise it will still cost a lot of dosh but not as much if you do all the work yourself.
What type of music do you mainly listen to?
coz that can determine what ice you need
Dave Pearce, hmm he mixes like a man with no hands
I got 3 subs, 2 amps, 2 eq's, power cap, split charger, all the cabling, Alpine head ... I got the TOP ICE...
just dont know if I should insert it all??!
I also dont wanna weigh the Nova down a lot as I want a 13 sec 1/4 mile Nova too!!
the iCE therefore has to be able to come out for Santa Pod track days!
13 seconds, hmm ambitious. u got a V8 in there or something.
i'd only put 3 in if they were 10" ers so 2 12" will be fine. but again it depends on what kind of music you tend to listen to!
look at the ice installs in car audio, lax flowers, slow car etc and get ideas from them, they are all do able by yourself, unless you have no arms and legs :D
get creative.
I want it to be portable too... to take out when I need to.
hmm...
ok, maybe not 13 secs, but as close to Jon Shield as possible!
2 12's more likely.
in that case try 2 12" in a pair of funcky pods on either side of the boot
BUT I also want it to be one of the loudest Nova's ever!!!
I WANT EVERYTHING !!!!
