Results 1 to 8 of 8
Thread: Heater Problem
    Member
    Mar 2004
    Ireland
    177
    Default Heater Problem
    My heater doesn't work!!!!! I'm so cold. But anyway, I was drving along and my heater stopped working. The fan still works but no heat. Its a 1.2spi mk2. Any ideas?
    Jan 2005
    Hull
    2,990
    If your carpet isn't damp and your coolant level is ok it could be that the control cable has come off. If the carpet is damp and coolant low then the heater matrix is most likely gone.
    Jan 2002
    Gloucester
    865
    I had this when I first bought "X". Several things...
    1. check the coolent level
    2. check the cables are still connected and working down to the heater box
    3. matrix blocked, pull off both hoses from the matrix in the engine bay and shove a hose up inside, flush it through from both sides until the water runs clear. Conect it all back together and refill your coolent.
    Member
    Mar 2004
    Ireland
    177
    The carpet is dry. I'm sure the coolant is ok. I'll double check in the morning before I go. The engine wasn't heating up too much so I'd say its fine. It never even got up to half way on the temp gauge after 2 hours of driving.
    Jan 2002
    Gloucester
    865
    OK, not to worry you but REALLY check that water.... The water temp guage doesn't work very well without water..... Just a warning
    4th year Membership Scab Club Member Dod's Avatar
    Sep 2004
    Co.Donegal ROI Currently: has no Novas...
    10,651
    I've got the same problem with my Nova, but its slightly different. It comes on itself but wont run steadily. If you turn the switch to1, 2 or 3 it doesnt work but after a few mins it comes on for a few secs and stops. This happens even when the ccars not moving, ie, not damaged wiring. Also the fuel gauge sometimes gives false readings.
    I spent 90% of my money on Drink and Women, the rest I just wasted.
    Member
    Mar 2004
    Ireland
    177
    The water level is a little low but its been lower so its not that. I toppd it up aswell before going to work this morning and it made no difference.
    Jun 2002
    Cleveleys, Lancashire
    4,104
    ok once the engines fully warmed up look down the back of the engine - you should see 2 1" pipes running into the bulkhead
    check to see if BOTH of them are hot (ie as hot as the main radiator hose) if they are its most likely the cable to the knob has snapped
    if one is cold then the heater matrix is blocked
