Results 1 to 2 of 2
Thread: Speedo drive
    Newbie
    Nov 2021
    Surrey
    6
    Default Speedo drive
    I plan on putting an astra mk2 gte digi dash into my nova.
    I have the dash, black n white plugs in the back and the digital dash and I have the transducer. I don't have the speedo drive on the end of the transducer (the toothed cog thing).
    Can I use a speedo drive from else where or will I need the exact one that would of been on the end of the transducer when it was installed in an astra gte?
    The engine in my nova is a c20let with an f28 gearbox.
    Any advice would be much appreciated.
    Thanks all!
    Club Member Club Member bazil's Avatar
    May 2009
    renfrewshire
    10,167
    If your F28 is a mechanical speedo drive you need to fit the black toothed speedo drive to the differential from a F20 gearbox
    the F28 used a blue ring with more teeth and isn’t compatible with the digi drive speedo drive or standard nova speedo drive
    success is only limited by a weak mind
