Results 1 to 6 of 6
Thread: Fuel tank for a redtop conversion
    Feb 2021
    2
    Default Fuel tank for a redtop conversion
    Hi all
    I have a K plate 1.2 luxe that's had a redtop fitted. Do I need to replace the existing fuel tank or will it run ok with an external uprated fuel pump ? I assume mine was an SPI car
    I've been advised I need a GTE or GSi fuel injected tank ?
    Thanks in advance
    13,604
    K plate will have been SPI which is a great tank for the conversion. You've been badly advised on replacing it with a GTE or GSi tank (let me guess, Facebook know-it-alls). It'll have an in-tank pump that sits in a swirl pot, the SPI pump should be replaced with an MPI pump (mk3 Astra etc in-tank) or an uprated Walbro one.
    Feb 2021
    2
    Mega cheers it has an external pump added is it best to just use this ?
    brotton , saltburn by the sea
    1,877
    Came to say they same as iain but hes already explained it pefectly
    If your running it about standard the mpi internal pump will be enough
    13,604
    Quote Originally Posted by retroted View Post
    You need to dig into that further. Shouldn't have or need 2. And an external one won't work properly without some mods to bypass the internal one.
    Sent from my ANE-LX1 using Tapatalk
    1,877
    Got a gte tank forsale if your intrested
