Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Bad fuel smell
    Dec 2011
    383
    Default Bad fuel smell
    Just wondered if anyone could help I am getting a very strong smell of fuel from the car I?ve checked all the fuel lines and there are no leaks drips ect everything seems dry. When I jack the car up in the garage a few moments later it?s like I have spilt some on the floor the smell is very strong any ideas
    Sep 2012
    Sutton, Surrey
    3,698
    Is the tank wet? Got a hole in it and leaking when jacked up? Its hard to say really as there's multiple places it could leak. May be a case of just following th fuel lines from the filler right though to the carb. Also check the breather in tbe filler neck, they like to dissolve
    Dec 2011
    383
    No tank doesn’t look wet for what I can see .all lines are dry an breather looks in good nik
    mybe a tank off jobby
    Administrator Admin Dan's Avatar
    Jun 2002
    F.O.D
    3,400
    2 Post(s)
    If it’s the braided type breather hose, these can visually look fine but like Millworm said the rubber inside the braid likes to break down and disappear which can’t be seen
    Jul 2002
    8,078
    Had a few instances of this in the past with various Vauxhall's. Tends to be a fabric braided hose, tank breather, fuel lines underside of hose on fuel rail which are hidden around the inlet manifold (depending on what engine you have). Use some soapy water spray on to the fuel hoses while running, it'll help you see if there's any air being being sucked or blown.
    Dec 2011
    383
    It’s not only when the car is running I can rock the car back and forth and a few seconds later there will be a strong smell of fuel in the garage but I can’t see any leaks or anything it’s like once the fuel has settled the smell goes away but if I shake the car the smell comes strong again. I’ll check that braided hose out
    cheers lads
    13,489
    The dodgy breather goes through a hole in the chassis to the filler neck so may not be an obvious leak.
    Jun 2005
    Norwich Norfolk
    905
    Does it do it at certain levels of fuel? My GSi one would do it on a full tank to 3/4, but that was a tank failing.
    Dec 2011
    383
    Today I jack it up on near side front to do some work went abit higher then usual an noticed fuel leaking from off side rear end of tank so going to investigate in the week maybe dodgy filler neck were it meets tank
    Dec 2013
    Kings Hill, Kent
    1,686
    Quote Originally Posted by jonnyd61 View Post
    My filler neck rotted away here and I had to get a longer joining hose to solve it
