Any one got any standard pistons cheap?
What are they for mate
8v turbo build pal.
If your only going to run standard pistons why not just run a decomp plate pal .
If you still havnt got sorted by xmas time give me a message i will have my wossners up forsale cheapish as changing to wiseco 87mm
Thought about that and couldn't find a place who does them. Any ideas?cheers
Ebay £50 mate
Cheap and cheerful solution if your just looking for low-mid power turbo build
If you do decide to go for rods aswell i would already have your motor stripped down and check the rod width and the bearing size as im pritty sure there is two different width bearing set ups someone will correct me if im wrong but im sure they are something like 19.5mm and 20.3mm .
Cheers pal. I've already stripped it down pal so will check. I might just go down the decomp plate for the time being.
Still need a set.
