Results 1 to 6 of 6
Thread: Misfire (ready to put a hammer through the windscreen 🤬)
    Club Member Club Member
    Jul 2015
    272
    Default Misfire (ready to put a hammer through the windscreen 🤬)
    My car has an annoying misfire,stutter,when driving say in 3rd going round a corner it stutters/splutters and does the same when cruising,iv fitted new plugs/leads/roter/dizzy cap.
    compression tested and all 4 cylinders at 190.
    carbs rebuilt by a well known man,rolling road pulled like a good one yet I still have this miss stutter.
    its a c16se on twin 40s.
    im fuming with it now,am I missing an earth?? Is the distributor goosed,any way I can test it???
    when you give it the beans it flys no missing or stuttering.
    blackpool
    3,414
    Have you checked the timing with a strobe light? Mine did this and it was out so undone the clamp on the dizzy and adjusted it by turning it until I got it right been right since.
    Jul 2015
    272
    What did you set timing to?? 10 because I keep reading it’s different running unleaded?? Is yours cammed up?
    blackpool
    3,414
    No it's not cammed I carnt remember I set it to what the Haynes said pal. Sure it was 10 degrees.
    Senior User mowgli's Avatar
    35,194
    Dizzy timing in Haynes is for leaded, it will need retarding a bit.
    35,194
    Right, I’ve been Away a while, and I’m getting my nova mojo back up to speed..
    you are running a c16se, on carbs, With a lumpy cam on a z16se bottom end, but what dizzy? A vacuum advance or something like mega jolt might be the only way to get it Smooth.
    did you have the head skimmed?
    are you running super or regular petrol?
