Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 70
Thread: 4x4 VXR Nova
  1. #21
    Junior User
    Mar 2018
    67
    The transfer box has a clutch that in standard format is locked by the power steering pressure, there is a kit available to lock this clutch given a 50/50 split between front and rear (someone please correct me if I'm wrong) so if a front wheel spins it will act like a open diff but still giving the full 50% drive to the rear.
    Sent from my CLT-L09 using Tapatalk
  2. #22
    Junior User
    Mar 2018
    67
    Also the gearbox has a double spline output to the transfer box, one driving the O/S drive shaft and the other spline drives the transfer box.
    Hope that helps you understand.
  3. #23
    Junior User
    Mar 2018
    67
    Daily update.
    Boot floor cut, chassis legs cut and a quick mock up to see how it all looks.
    Bearing in mind this shell has never been welded untill I started this.
    It has hard putting the plasma torch to it.
  4. #24
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    Quote Originally Posted by Aron 6pot View Post
    That makes more sense I had kind of assumed it was simply a diff output to the TXB etc. cool stuff
  5. #25
    Senior User Rickyb's Avatar
    Apr 2007
    blackpool
    3,057
    This is a very cool project, I hope you get lots of progress on it great work.
    Seing great projects like this will make this lockdown fly by.
  6. #26
    Junior User
    Mar 2018
    67
    Update!
    After fitting the rear subframe I found it to be a little to wide.
    As I'm going for the stock look, I decided to cut 3" out from the centre of the subframe before reinstalling it.
    I am much happier with how it looks now, from the outside view you can't see anything is any different to a stock nova.
    I now have some upper suspension arm clearance issues but nothing that the cutting can't fix.
  7. #27
    Norwich
    5,659
    Nice work around
    I take it diff still has plenty of room?
  8. #28
    Aug 2007
    Lelystad, NL
    1,106
    Brave man for putting the plasma torch to a solid shell. But needs must etc. so it's all good.
    Also thanks for explaining the transfer box double shaft layout, this was new to me too.
    Sent from my Nokia 6310i using the keyboard
  9. #29
    stoke
    1,990
    Love it dude. I've been dreaming of building a 4x4 nova recently I'll be keeping an eye on this. ��
  10. #30
    Junior User
    Mar 2018
    67
    Nice work around
    I am using the cav rear diff so need to make mounts anyway but yes still fits. To be honest it's done me a favour as now I can use the original Cav rear drive shafts and have them machine down to fit the outer mx5 CV joints.
