Results 1 to 7 of 7
Thread: Screen fitting
    Aug 2008
    blackpool
    3,417
    Default Screen fitting
    Iam gonna be fitting my new screen and rubber any tips on this? Best to use window cleaner as lube?
    Sep 2005
    brotton , saltburn by the sea
    1,876
    I always use washing up liquid and insulated wire it seems to pull round easyer than string . Done loads over the years without a problem
    Aug 2008
    blackpool
    3,417
    Ok will give that a go. Is it a case of making sure the rubber is nice and lubed up. Thanks pal.
    Jan 2004
    Ash vale, Hampshire
    1,474
    Washing up liquid is not a good thing to use as it contains a lot of salt, window cleaner works well, and make sure you use a good strong cord, I find the stuff used on washing lines works well.
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    Rear or front?
    I used washing line as it has enough slip on it so didnt need any lube, fnaaahhh
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,605
    Don't bother with any sealant/adhesive either.
    Aug 2008
    blackpool
    3,417
    Ok cheers lads.
