Would the facet be ok to run in engine bay? Or closest to tank?
I know there suppose to be used vertical so is there enough room under the car? Will also use a filter king pressure regulator.
Sent from my SM-G920F using Tapatalk
Any pictures of how yours is done please mate?
Also would it be a good idea to use a swirl pot so it doesnt suffer if the tank runs low?
Yes, but if it goes any lower it still will not help you
Not sure it will help you buddy as mines isn't a road car facet is inside the car as is the fuel lines up to the pressure reg & a return from the reg for
the excess fuel back to the tank or swirl pot, if you have a swirl pot then it will have an over flow back to the tank.
I can email pics if you still want them as photobucket is doing my head in most other forums I'm on you can add pics from your laptop
(WHY NOT ON HERE AGGGGHHHHH)
Ok thanks yes please be good to see how it all goes then give ne sone ideas.
Send me other some in the messenger or u want my email?
