Results 1 to 5 of 5
Thread: While the head is off my 12ST.....
    Jun 2004
    Down Under
    2,241
    Default While the head is off my 12ST.....
    Im going to refurb the head on my 12ST as its got a leaky core plug and figured while its off the road i'd refurb it. Head gasket, belt, stem seals, etc etc. Plus Im bored and enjoy these things.
    Is there anything i can do whilst im in there to perhaps gain a little power? Someone mentioned adding a 1400 bottom end which sounds reasonable. C14NZ and C14SE's are available here so im tempted. Would the carb be up to it?
    Any other advice?
    Thanks
    Jan 2004
    Ash vale, Hampshire
    1,471
    You could give it a quick port, there's plenty of videos on YouTube and then have it skimmed.
    Club Member turbojolt's Avatar
    Jan 2007
    derbyshire, derby, shelton lock
    10,358
    If you can find one add the camshaft from the 1.3 Sr, 13sb is the engine code iirc
    ^^^ did you just read that? what a idiot ^^^
    PROJECT 2 FAST 2 FAT clicky
    ''lifes what happens, while your busy making plans''
    Sep 2006
    Nottingham
    1,802
    Check the valve guides before you consider any other parts. A good upgrade is 1400 sr cam and carb, if you can find them.
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    1400 carb manifold is god awful though.... And the same car as the 1300 iirc.
    1300 cam gives 5bhp on a std 1200
