Results 1 to 6 of 6
Thread: Idle problems 20xe
    Club Member Club Member
    Nov 2011
    berkshire
    711
    Default Idle problems 20xe
    My 20xe used to idle fine but I had the throttle body machined out to 68mm. Now i've fitted it back with a new gasket but when I pull up at lights etc the car idles at 2000-2500rpm and I cant seem to get it running slower. I cant find any air leaks etc but the car was running fine before I had this done. Any ideas anyone??
    Aug 2006
    I live inside your pants
    4,527
    Did you fit a larger butterfly?
    Nov 2011
    berkshire
    711
    The person who did the work fitted a new butterfly to match, its a snug fit and it closes fully when you take your foot off the throttle.
    Moderator Moderator conza123's Avatar
    Dec 2011
    Sandwich kent
    2,339
    2 Post(s)
    Leave it running and just spray carb cleaner round the throttle bodies etc and see if the revs go up as u mite still have a small leak somewhere
    Aug 2006
    4,527
    Setup the TPS and check for leaks.
    Jun 2006
    Cheadle, stoke-on-trent.
    14,968
    if you've still got the sfi donut i'd check for leaks here first
