Results 1 to 6 of 6
Thread: Fitting C20SEH without modding chassis leg
    Feb 2007
    lisburn northern Ireland / Portsmouth Hampshire
    1,572
    Default Fitting C20SEH without modding chassis leg
    Lads i have just had my whole car resprayed and engine bay sitting pristine, although i made the school boy error of not modding the drivers chassic leg to accomodate the altenator on the 2.0 engine, I heard from a few people that you can get away with fiddling with the altenator setup to clear, i just dont want to muck up a freshly painted bay and beating the chassis leg in as it will look a sight any help would be great or photos of how others have got around it cheers
    Apr 2011
    wiltshire
    1,938
    Mount the Alt down the front where the power steering pump used to be.
    Senior User mowgli's Avatar
    35,194
    it has been done times. look at the alternator mount bolts & see if you can't make some space there
    13,604
    Can't take it too far out of line with the bottom pulley though or you'll have the belt inverting or trying to escape
    As Craig says, off the front sounds like the approach you need to take, unless you can clear enough space and mount the engine so there'll never be any movement
    23,813
    You can some times get away with machine both pulleys down on the alt, removing a washer and trimming down the nut (all lathe jobs) and then cutting the shaft down as short as you can make it.
    They will give abit of clearance. But it will either touch or be very very close when you corner.
    I ran mine like it for a few years, as the clearance i made wasn't enough.
    Oct 2007
    Cudworth, Barnsley, South Yorks. Drives: Nova 2.0 16v hatch.
    2,775
    When i fitted my 20xe i only very lightly modded the chassis leg with a hammer an block of wood an its never touched when cornering i even run the twin vee bottom pully with no issues.
    Damo.
