Hi my battery is either not charging or bejng drained, replaced the alternator and checked its working(which it is) but the battery keeps going flat. Changed battery for a new one its still going flat any advice cheers
Does the altenator have the earth strap c onnected correctly?
How did you test the alternator and come to the conclusion that its charging in the first place?
Either:
its not charging
The battery is faulty
you have a drain
Or a combination of the above
it might be something silly, like the boot light is staying on.
ive seen various occasions where people have wired up amps/subs wrong, and they have a permanent drain, which flattens the battery in less than a day
I once put a screw through the wire for the bootlight and spent weeks trying to trace the drain!
