Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Equal Length Driveshafts on a Smallblock Gearbox
    Club Member Club Member novarally's Avatar
    Jun 2002
    Poole, Dorset, United Kingdom
    8,490
    Default Equal Length Driveshafts on a Smallblock Gearbox
    Forgive me if this has been discussed before on PNG - I have done no research on the subject at this time.
    But the question is simple............is there a way to run equal length shafts on an F10/F13 gearbox (i.e. on standard size CV output flanges)?
    Thanks.
    Colin
    To contact me please use E-MAIL to colinesmith@aol.com.
    thousands of Nova (plus other Vauxhall and motorsport parts) available.
    Sep 2009
    Leeds, Yorkshire
    6,211
    It may be worth contacting Ben (boffer8) as I know this is something he was looking into. No idea whether he is still researching this though
    Sep 2008
    Bridgwater
    12,248
    I'd like to know about this also
    Can't see how you'd use a CLET set up
    Corsa D's have a set up
    Club Member Club Member bazil's Avatar
    May 2009
    renfrewshire
    10,167
    The corsa vxr middle shaft is shorter than the big block one but ive not tried it against a block yet or counted the teeth,
    I have both somewhere i could dig out
    Edit,
    Im talking pish, the corsa one is longer and the gearbox end is 24 spline, cv side is 34 spline
    success is only limited by a weak mind
    Jan 2008
    1,176
    just use a big block gear box and run the nova equal lenght drive shaft set up onto thing i will have to make it an adapter plate to bolt the drive shaft bearing mount to
    Sep 2008
    Bridgwater
    12,248
    I wouldn't want a big block box on there, too heavy
    Jun 2002
    8,490
    Quote Originally Posted by Edd View Post
    Indeed, as Edd correctly identifies, that is the whole point of this post, I don't want to use a big block gearbox!
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    You can get small block diffs with big block output flanges. Rallymarshal (Paul) knows the dealio.
    Jun 2002
    8,490
    Quote Originally Posted by Iain View Post
    Iain - not wanting to do this either, I want to use standard Nova shafts and CV's.
  10. #10
    May 2009
    renfrewshire
    10,167
    Corsa vxr one doesn't fit, tried it today it needs large side gears on the diff neither the XE or vxr brackets match the bolt holes on the back of my E16 block,
