Hi guys this a bit puzzling, I was racing my 14se at the weekend. Previous to racing all four cylinders were equal at 200psi, I check the pressure after it failed and I had 1) 30psi 2) 30psi 3) 200psi 4) 200psi. And there was pressure in the breathers. I've took the head off the gasket is fine, I've poured oil in the bores and there not passing. The only thing I can come up with has the head warped or lifted due to the comp stil being in the oil ways.
Any suggestions please guys.
