Decided, even though i pretty much have everything to build the Nova, that im not going to do it. Got another project on the go so just gonna do that. So here goes,.....
Fully Forged bottom end inc. +0.5mm forged pistons, rods, under piston oil squirters, steel gears, ARP’s throughout, brand new oil pump with steel gears and SBD nylon relief valve. Check the thread build for L401 TOY on Migweb.co.uk for more info. Hasn’t done any miles since I bought it off him.
Sold
Coscast Head. Zero miles. Polished, ported, skimmed the minimum amount, XE cam, uprated valve springs, Kent pulleys. Mint condition
£400 Sold
C20LET TD05 Turbo set up. Japspeed Tubular manifold, big 16G housing.. C20LET flange plate welded. Ready to plumb in and go. £350 Sold
Custom inlet manifold and throttle body for C20Let/C20XE. Big plenum. Has been mated up to Let inlet/head connections. Just needs tidied up. £170 Sold Deposit taken
550cc Injectors £70 Sold
LET/XE lightweight aluminium crank pulley. Brand new, £30 Sold
F28 Box. All Good. £230 Sold
Quaife Diff £350 Deposit taken Sold
Sachs 4 Paddle Clutch. Perfect condition. Inc plate £250 Sold
Lightened & Balanced Pot Flywheel £50 Sold
Full 3” JapSpeed exhaust off an Evo. Same flange as turbo. Ready to be welded to fit any car £120 SOld
2x AFM £45 each SOld
Let Phase 3.5 EDS ECU with power wheel £300 Sold
Let wiring Loom £80 SOld
Standard Let ECU no chips £50 Sold
Nova Rolling shell. Fully restored 3 years ago on a jig. No rot at all. Has been badly re-sprayed white though.
£500
Nova GSI kit. Bumpers and skirts, £100 Sold
Nova Roll Cage. Safety Devices. Bolt in. Brilliant condition £250 SOld
Nova equal length drive shafts inc. CV’s £60 Sold
Audi Quattro bearings and big block outer hub flanges to do the proper conversion (not the pishy M-Tec one) £50 Sold
Nova / Corsa B FK Blue coilovers. Not many miles. Not the cheap yellow ones. £150 (Bargain) Sold
4 Stud V6 Brakes £40 Sold
Speedlines, Black, Brilliant condition, no kerbing. All Centre caps there. Tyres, but not great £250 Sold
Digi Dash with transducer and plugs £60 Sold
Nova OMP front strut brace. Red. Great condition. £40
Nova 16 plate strengthening kit £70 sold
Nova poly bush kit, front and back. £70 sold
Nova – Let/XE Aeroquip fuel lines. Expensive parts. Brand new £30 Sold
Nova Let/XE with F28 mount set. Includes brand new rubbers. £90 sold
Nova Blue Antibes carpet (Rare) great condition £30 Sold
Let / XE started motor £25 sold
Let / XE Alternator £20 sold
Let Timing belt, brand new £10 sold
Let standard pistons & rods, £40 Sold
Let block with crank, slight lip on bores, just at the top, £30 Sold
