Page 178 of 211 FirstFirst ... 78128168176177178179180188 ... LastLast
Results 1,771 to 1,780 of 2103
  1. #1771
    Norwich
    5,659
    So, here we go again then.
    All set up at Brands and ready for whatever tomorrow brings!!
    Hopefully some videos will be incoming.
    That must be a real ass to jack it up high enough to get those stands on surely?
  2. #1772
    Jun 2002
    Poole, Dorset, United Kingdom
    8,490
    Having had those same stands, and a Nova, I would say ‘yes’!
  3. #1773
    Dec 2013
    Kings Hill, Kent
    1,889
    I have a cunning jack!!!
    It weighs a tonne but lifts to 850mm so it's not too bad
    Only stuck it on the stands so no-one could push it away overnight!!
  4. #1774
    Dec 2013
    Kings Hill, Kent
    1,889
    Good luck at brands, hopefully you don't overheat and blow coolant everywhere.
    Pesky stuck thermostat
  5. #1775
    Dec 2013
    Kings Hill, Kent
    1,889
    First little adventure of the day.
    https://youtu.be/aRWSmhkmXKE
    Coolant boiled over and front tyres first, then rear tyres, bit of tree chopping and got straight into the pits.
    I could see a fluid coming out so switched off straight away.
    Water temp was up at 102, oil 106, I've seen those temps before so wasn't worried as it was a hot day
    After an age to cool down, decided to whip the stat out and run statless. Luckily I did, it was jammed solid
    No idea what this residue is, looks like RTV but it's not RTV as I haven't used any in the coolant system. It felt quite solid, really weird.
    Anyway, stat removed and engine ran at 80 water 95 oil for the rest of the day, which I'd say is about right for me.
    More videos incoming.
  6. #1776
    Dec 2013
    Kings Hill, Kent
    1,889
    https://youtu.be/j1K8MicjfO8
    Chasing Team Brit car BMW.
  7. #1777
    Norwich
    5,659
    She moves! Looks like you had fun as always once the issues were ironed out.
    You're running a sequential box aren't you? Do you still have to dip the clutch then? Had to see depending on the lighting, but looks like sometimes you do and sometimes you don't?
  8. #1778
    Dec 2013
    Kings Hill, Kent
    1,889
    Yes mate sequential box.
    So I always dip the clutch on downshift, I just can't get my head round not dipping it on downshifts, trying to help it last a bit longer. I know under heavy braking I could and have used clutchless downshifts but I don't like it!!
    On upshifts I don't like clutchless up shifting with lock on as it feels like it doesn't like it,
    3rd to 4th out of paddock I should be clutchless
    2nd to 3rd our of Druids I should be clutchless
    3rd to 4th on the bottom straight should be clutchless
    But 3rd to 4th out of Clearways I used the clutch as I had lock on.
    But I also sometimes forget and use the clutch whatever gear I'm changing into!! It's an element of my game I need to work on, along with left foot braking and braking harder and later.
    I've only just got my head around gassing on before the apex and using the throttle and diff to pull the line tighter and kill the understeer something that I've only just realised at brands and how much quicker it makes you.
    From the videos I'm around 57 seconds compared to a minute at my last Brands day. I think the car has a 54 or a 55 in the hands of a real driver. I'm gonna get my Vbox sorted and actually start to work on these things.
  9. #1779
    Jun 2007
    865
    Great to see you back out using it bud, haven’t looked at the videos yet but that car should easily do 53,s , if you have a passenger seat next time you are there let me know and I will come and gee you up a bit
  10. #1780
    Dec 2013
    Kings Hill, Kent
    1,889
    Fuck me mate i'm doing 58's. I need some help!!!
    Not that it's an excuse but I'm on 888 semi slicks.
    I wonder how much time would be gained on slicks, a second a lap???
