Page 189 of 211 FirstFirst ... 89139179187188189190191199 ... LastLast
Results 1,881 to 1,890 of 2103
  1. #1881
    Dec 2013
    Kings Hill, Kent
    1,889
    Got a bit of white on the walls.
    Second coat required
  2. #1882
    13,604
    Beer fridge?
  3. #1883
    Dec 2013
    Kings Hill, Kent
    1,889
    Beer fridge?
    Is there another kind??
  4. #1884
    Dec 2013
    Kings Hill, Kent
    1,889
    Car will be at VBOA, but won't be running as the wiring wont be done.
  5. #1885
    Club Member Club Member
    Jun 2005
    Norwich Norfolk
    1,013
    Be good to catch up with you mate.
  6. #1886
    Dec 2013
    Kings Hill, Kent
    1,889
    Busy day today,
    when I moved the car off for wiring a few weeks ago there was a puddle of oil under the car.
    Couldn't really understand it, as when it's running there was nothing pouring out....
    Believing it to be crank seal we whipped the box out in 45 mins flat.
    Despite a bit of oil out the bolt holes the seal was surprisingly dry... got the air line out to clean and blow it of, as the nozzle got onto the sump join to the block an explosion of oil out the crank bolt holes!! Bloody sump leak.
    So off with the sump, 3 bolts round that end loose!! School boy error when I fitted them, no sealant on the threads at all.
    Clear to see!!
    Bit of cleaning and some 3 bond
    Then I snapped a bolt putting it back together!! With luck on my side (for a change) I managed to work the broken bit of bolt out with a pick!!
    Clean and reseal, back together.
    Flywheel and box on quick wash and it's ready to be a paper weight at VBOA!!
  7. #1887
    13,604
    Snapped a sump bolt!!! How tight you doing them!?
  8. #1888
    Dec 2013
    Kings Hill, Kent
    1,889
    Piss off pal.
    I barely did them up. I was surprised as it normally strips the thread instead of snapping the bolt.
  9. #1889
    Jun 2005
    Norwich Norfolk
    1,013
    You don't know your own strength...
  10. #1890
    13,604
    Houses arms are calibrated. Unfortunately the calibration is between small ogre and large ogre.
    Piss off pal.
