Results 1 to 7 of 7
Thread: Gearbox and engine identification
    Nov 2013
    RAF Lossiemouth
    25
    Default Gearbox and engine identification
    Can anybody tell me exactly which engine and gearboxes these are please. They are (probably) from a 1991 1400
    Thank you in advance
    9,086
    Can you see a stamped engine number? If so, it should tell you the engine type on there. If it is a 1.4 it could be a 14NV or C14SE etc.
    The gearbox should have a stamped in number on the outside of the casing at the bottom. It could be an F10, F13 or F15. It should also be stamped WR for wide ratio or CR for close ratio. Then the final number will be the final drive ratio like 3.74:1, 3.94:1, 4.18:1 etc.
    For example a GTE box is F13CR 3.74:1 if I remember correctly.
    9,086
    Looking at the oil breather on the back of the block I suspect it is a 14NV.
    Nov 2013
    RAF Lossiemouth
    25
    Aha, I'm looking at the wrong numbers then. I will see if I can have a look tomorrow. I have seen those designations discussed on here, I will do some googling.
    While we are at it is that what I think it is... a LSD :-)
    9,086
    It is not a standard diff so likely to be an LSD
    Nov 2013
    RAF Lossiemouth
    25
    Cheers, I hoped that it was, I will have to do some research into how to take advantage of a LSD in a FWD car, I've never driven one, I have owned more RWD cars than front.
    May 2009
    renfrewshire
    10,167
Tags for this Thread
