Results 1 to 6 of 6
Thread: mk3 cavalier running with key out wont turn off
    Nov 2011
    newcastle
    17
    Exclamation mk3 cavalier running with key out wont turn off
    i have a c20xe mk3 cav due to a porous head i swapped the original for a costcast
    this is where the problem began started the car ran fine revs up fine etc...
    but it idles at 1100rpm and wont turn off with the key any help appreciated
    thanks
    Senior User nova_saloon's Avatar
    Jan 2007
    London, United Kingdom, United Kingdom
    2,609
    Sounds like it could be the alternator switch, it seems to be keeping the car running, it is a common problem. there is a little lead that plugs in to the back of it just pull it out, if it dies then there is your problem. Or there is a short somewhere else
    Nov 2011
    newcastle
    17
    Champion mate al try that after work tommorow
    Nov 2011
    newcastle
    17
    Also what do you mean pull the feed off like as in an ignition live because am pretty sure its only blue and white and a red wire cheers again
    Aug 2003
    flint Nr Chester
    3,941
    i'd take the blue/white off
    Nov 2011
    newcastle
    17
    Wil try that mate cheers but its only battery light a think because it wasn't wired up when I got the car
Tags for this Thread
