any one done it ? how easy?
cheers peeps
cheers peeps
put in key turn to position 2 then with a small allen key push the key way down should then simply slide out !
there is a small hole above the ignition barrel in the barrel housing this is where you put the allen key
job done next !
forgot to say its a piece of p155 should take about 10 mins with removing the steering shroud
good man job done mr grunt
rep'd to
thank you big boy !
hammer, and screwdriver!
