Results 1 to 8 of 8
Thread: Help.
    Club Member Club Member Pistol Pete's Avatar
    Oct 2002
    Swindoncestershire Building: A Breeze Blue XE
    12,849
    Default Help.
    Got a weird issue.
    When i press the brake pedal, the indicator light lights up on the dash. I can also hear the relay clicking. I also buzzes when the engine is running, but stops when the indicators are in use.
    Would this be relay related? Or a bad earth?
    My Rebuild
    Club Member Club Member Royston's Avatar
    Oct 2007
    Near Darlington
    3,549
    Would suspect a bad earth
    Somewhere
    Regards
    Royston
    Oct 2002
    12,849
    cheers!
    My Rebuild
    9,086
    Poor earth at the rear light unit I should imagine. Check the earth at the back and the light unit circuit & wiring plug
    Oct 2002
    12,849
    Checked all the above. Still doing it.
    What's strange is the indicator light doesn't stay on. It briefly flashes as the pedal is pressed.
    My Rebuild
    Oct 2002
    12,849
    Right new relay cured the light showing. But I still get a buzzing from the relay when the engine is running. Confused and frustrated!!
    My Rebuild
    Oct 2002
    12,849
    Anyone?
    My Rebuild
    User windfreek's Avatar
    Feb 2011
    Mallwyd, thats rally country to you! . . Drives: . . . . .1.7TD Novavan
    476
    do the hazards work as expected and the same for both left and right indicators work accordingly without the engine on just ignition?
    Have you checked your running voltage across the batt terminals in case its your alternator on the way out?
