Results 1 to 7 of 7
Thread: central locking interface
    Junior User
    Mar 2007
    st albans
    78
    Default central locking interface
    does anyone out there no what wires get connected for the central locking using a sparkrite sr 911 interface.
    thanks
    Senior User Graeme's Avatar
    Nov 2007
    Warrington
    8,948
    You need to swap the drivers door actuator to a five wire one and feed that a positve trigger or add a two wire one
    Junior User
    Mar 2007
    st albans
    78
    its already got a actuator in the door with two wires going to it as its the sr, so i still need anything else
    Nov 2007
    Warrington
    8,948
    The factory set up only has a three wire switch and not an actuator, so will need swapping or adding to
    Junior User
    Mar 2007
    st albans
    78
    sorry for all the questions. i have seen a five wire universal one. do i remove the existing one i take it, also do i need one for the passenger door
    thanks
    Nov 2007
    Warrington
    8,948
    If it has the factory central locking set up you just need to swap the one in the drivers door, any five wire universal one should fit as long as it has the same mount screw spacings
    Jul 2008
    Unknown
    9,635
    What did that was not ideal was put a passenger solenoid in the driver side so it only worked with the fob and not with the key but a 5 wire one is a solenoid with the switch inside too so still works with the key
