Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: XE Conversion rewiring- non starter
  1. #11
    Nov 2008
    Chester, Cheshire, United Kingdom
    7,282
    Sounds like earth problems to me.....
  2. #12
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    Quote Originally Posted by VR4AWD View Post
    Right i changed the wiring to the one it should be and the car fired up right away.
    now its still overfuelling terrible and after 2 mins running i have to dry the cylinders and clean the plugs before it will allow me to start it again.
    heard the temp sensors are usually to blame but how do you check them with a multimeter before i go any further with it.
    any advise would be great as its now at the finishing line but just a niggle now to get it running right.
    also what ford plugs do people use as iv heard its NGK PTR5A10, the plugs fitted are dud and only a tiny spark if anything so wondering if this is part of the running problem.
    can anyone give me some more advice ?
    just get a new cts (coolant temp sensor), they are cheap and usually at fault. i assume the cooling system is free of any air, cos it needs to be.
    just stick with std factory plugs, they are fine.
  3. #13
    Moderator Mazz's Avatar
    Jun 2005
    Stafford.........Drives : Audi A4 + NOS Nova GT'XE
    6,657
    1 Post(s)
    If its a standard XE, just fit GM plugs.
    (┌∩┐(◣_◢)┌∩┐)
  4. #14
    NW BOYS Club Member Riggy's Avatar
    Jul 2003
    United Kingdom
    11,735
    also check for any air leaks around the throttle body as that can cause it to run rich , also a dodgey AFM , but as you have also said ,CTS is a good starting point
  5. #15
    Senior User dc1984's Avatar
    Feb 2010
    Renfrewshire
    1,985
    i had a problem getting mine to start at one point, turned out that it was the coilpack wasnt earthed to its bracket after i got it powdercoated.
  6. #16
    Newbie
    Aug 2010
    12
    still problems but it now runs, i will update or create a new topic tomorrow with all problems im having with this as something still isnt right and customer has it pre sold.
  7. #17
    Newbie
    Aug 2010
    12
    now done more work to it but still has a problem i cant get to the bottom of if anyone can help.
    http://www.pngclub.com/forum/showthr...unning-problem
