Results 1 to 2 of 2
Thread: 1995 Mk3 Astra LS 5 Door 1.4 8v MPi
    Nov 2008
    Northfleet Kent
    775
    Default 1995 Mk3 Astra LS 5 Door 1.4 8v MPi
    Car For Sale
    Make and Model
    '94 Astra 1.4i LS MPi
    Description
    Reluctantly selling my Astra, I use this daily, as the GSiT is to juicy to use day in day out.. I dont want to sell... but a diesel van has come up and i could really do with one of them for what i do... This has never let me down or failed to start at all...
    - Mileage currently 124k but I still drive it a few times a week (engine should be just under 110k - I had this taken from an 83k mile auto when I had the MPi conversion
    - Has 10 months MOT (from Feb '10) and tax until end of June (6 months £64 or there abouts)
    Good points:
    - Clean shell, no rust or rot which is good for a phase 1 model (Bit on one front wing)
    - Remote central locking and alarm
    - GSi seats front & rear
    - Black interior from a phase 2 GLS
    - Tigra 5 Spoke alloys with good tyres
    - New rear brake cylinders, drums and shoes
    - 256mm front discs and red calipers from a GSi
    - No fluid leaks or head gasket failure
    - Tracking is a-ok
    - Waxoyl'd rust-free inner rear arches and connected roof drain pipes to reciprocals
    - Peco twin DTM backbox (cost £180, sounds deep and reverberates not raspy and chavvy)
    - Recent standard mid-section exhaust replaced
    - decat pipe fitted
    - Serviced 2k miles ago with oil and filter, plugs, brake fluid and cambelt kit
    - Recent lambda sensor (£60 or so from Vaux)
    - New oil pressure switch
    - Fuel tank previously replaced with new and undersealed
    - Electric aerial in rear wing
    - Drives really well
    - Home-made gear and handbrake gaiters
    - You can drive it home and it won't fail you
    - Reams of receipts for parts from Vaux and motor factors for £££ (seriously loads of money)
    - I'm sure there's other things but will edit as they come to me
    Bad points: (will be fussy)
    - Small amount of rust bubbling at the bottom of the n/s/f wing, doesn't look major
    - Paintwork isn't amazing as you'd expect for a 16 nearly 17 year old car.
    - Had diagnostic read before MOT and it flagged up lambda sensor faulty, lambda has been replaced
    - No EML on (and yes the bulb works).
    - One wing mirror is black, the other rattle-can colour coded
    Pics:
    Please Ignore Wheels In Pictures... They have gone. Any more pics required please ask!
    You are welcome to view in the light, run it from cold, take a test drive as long as you're insured and don't drive like a dimwit, poke and prod at your leisure but please don't kick the tyres.
    If, like me, you can speak Astra all day I may even put the kettle on
    V5 Is Present... Along with Tax Renewal Form & Previous MOT etc.. It Has 2 keys..
    £600 ONVO
    Thanks
    Nov 2008
    Northfleet Kent
    775
    Here's a few pics with the Tigra alloys on it... And one more of interior .. Thanks
    Cheers
