Profissionally remachined discs to fit your 4 stud Nova.
The kits include brand new GENUINE Vauxhall Calipers, discs and new pads. Police spec. pads are also available at a small cost. You won't find these cheaper anywhere :wink:
256mm "16v" Kit - ?200
2 x 256mm vented discs, to fit Vauxhall 4 stud hubs
2 x Astra GTE 16 valve calipers
1 x set of pads
Minimum wheels size: 15"
288mm "V6" Kit - ?250 (shown)
2 x 288mm vented discs, adapted to fit Vauxhall 4 stud hubs
2 x Vectra V6 calipers
1 x set of pads
Minimum wheels size: 15" (Wheel balancing weights may need to be moved to the inside edge of the wheel to clear the caliper)
Discs also available on their own, INCLUDING pads ?90.
308mm "Vectra B 2.5V6 Gsi" Kit - ?400
2 x 308mm vented discs, adapted to fit Vauxhall 4 stud hubs
2 x Vectra V6 Gsi calipers
1 x set of pads
Discs also available on their own, WITHOUT pads ?130.
Minimum wheels size: 17"
PM us or call evenings on 07792 453684, if you get the answering machine leave a message and we'll get back to you ASAP :D
