Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 'repairing' arch
  1. #11
    Oct 2008
    Essex, United Kingdom
    6,500
    Quote Originally Posted by daleNOVAbrennan
    you would have to get rid off ALL the rust anyway to avoid its return
    The rust is cut out, hence the two gaps
  2. #12
    Nov 2009
    widnes,cheshire
    200
    Quote Originally Posted by ConnorLake
    all as your doing is skimming the edges were you cut so there straight not exactly going to hack the lot out are you.
  3. #13
    13,604
    See how much repair panels are - the hatch rear arch ones are only about £8-10 I think?! If they're similarly cheap for the saloon you might as well get some and just cut out the bits you need. At least it'll be less effort in bending the plates to fit the shape of the arch.
  4. #14
    Sep 2007
    Forest of Dean
    916
    Just put a proper arch repair panel in, theyre cheap and it'll save doing the job again which you will end up doing if you botch it as the rust will end up pushing back through within a few months.
