Results 1 to 10 of 10
Thread: 1.2 with 1.4sr cam setup no spark
    User Copers's Avatar
    Jan 2007
    Saltash
    193
    Default 1.2 with 1.4sr cam setup no spark
    fitted my 1.4sr cam, ignition setup and coil yesterday, now have no spark, can i wire my original coil into my new dizzy/ignition setup which as a 2 pin plug on it, the coil that come with has two 2pin connectors on top and then a 6pin block on the bottom bracket, which i dont know what it is, heres some pics to explain
    any ideas needed asap please
    Original
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Do you have the 1.4sr mini loom for the coil/module/dizzy???
    NORA IS DEAD JordyzNova's Avatar
    Mar 2009
    near BRUM !
    1,371
    Quote Originally Posted by Copers
    Original
    the bottom picture you have you need the loom of a 1.4 to run tht coil witch comes with a big plug witch is the6 pin coonector an the little to pin one you run the black wire into a igniton live i hope this help ?
    ive just done same with mine
    Jan 2007
    Saltash
    193
    no, all i got was the coil, ignition and cam
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Thats why you have no spark then. It has a loom unlike a 1.2, because it has that 6pin module underneath the coil
    Jan 2007
    Saltash
    193
    i take it theres no way of wirin the standard 1.2 coil in then?
    Mar 2009
    near BRUM !
    1,371
    u need the loom as there a big plug underneath as adam said . . .
    Jan 2007
    Saltash
    193
    cheers lads, trying to source one now
    Mar 2008
    SE London
    4,406
    unlucky about the mini-loom mate. once you get it, just join the car loom ' black ' to the mini-loom ' black ', and the ' brown ' on the mini-loom, youll need to extend the wire and earth somewhere to complete the circuit, should be bobs yer uncle after that
  10. #10
    Jan 2007
    Saltash
    193
    cheers buddy, trying to get hold of one, no luck yet, if anyone knows of any send my way cheers
