why doesnt dutch mtech have this? he's just an overpriced **** :S
is that something to use in sales pitch?Originally Posted by mattatmtech
Not slating your product, just the ISO shizzle.... You could build a 3 legged table aslong as it conformed to ISO9xxx it would be fine, but as a product fall over.
How much for a naked ecu? and does it use the standard available MS interface software? oh and does it also use a non obsolete micro?
No its the factory that makes them, means that the quality is repeatable and of a high standard
An ECU with loom is £495+VAT, and the mico is surface mount, and RoHS compliant so yes you can get them, not that you would need to as our system is designed to be a sealed unit.
In terms of software you can use Megatune etc but we provide a much better system (under license) to use for mapping.
Cheers,
Matt
I think what Stu is getting at is that with ISO9001 you state what you set out to achieve, document the process and have a checking procedure in place. Therefore if you state you are going to make a 3 legged table, can prove the build process and test that you actually have a 3 legged table and are able to demonstrate you could make another one then you are ISO 9001 compliant.
Not knocking the product btw sounds mucho interesting.
yes see what you mean We set to deliver a great EMS with a great price, and we did it :D
Where can we see more - web address? Is the software available to look at in advance (like DTA) ?Originally Posted by mattatmtech
Edit: Found the URL in your profile (small typo tho chap http://www.mtechwutomotive.co.uk )
Links wrong , i did mention it, dont think hes got round to changing it!Originally Posted by phazer
http://www.mtechautomotive.co.uk
Try that
Yeah I worked that out
Ahhhh well you never know!!Originally Posted by phazer
Fixed it
Theres a deal we're doing (I don't want to really advertise until trad status is sorted etc. but...)
Jenvey Tbs and V4 ECU Supplied Fitted and mapped on your typical XE/4 pot etc £1,880+VAT. Thats a drive in drive out service
V4 ECU supplied fitted and mapped £995+VAT
Jenvey TBs and V4 ECU Supply only, £1,350+VAT
V4 ECU Supply Only £495+VAT
If someone can do a group buy and get 5x orders I will offer the V4s for £450+VAT with free mapping for the organisor.
Cheers chaps!
Matt
