was out in the car tonight, was taking it easy with the snowy roads
turned the heaters on and it was cold
temp guage was nearly in the red
car had been running perfect since i bought it (2 days ago ) temp always sat at half way
pulled over and switched engine off and checked the header tank, had lots of pressure and the water came out when i undone the cap slowly
i topped it back up with water and let it run for a bit with the cap off, it ran fine for a bit with the ep just under half the i started bubbling up again and going down then back up
then the water went away quickyly, topped it up again and it done the same up and down
ive left it there for tonight as its freezing outside
i forgot to put the blowers on full when letting it run
please dont say its the headgasket only had it 2 days, could it just be an airlock?
its only a 1.0 headgasket easy enough to do on it? never done one on ths small an engine
you can also feel theair bubbles in the system when is running
