Page 51 of 78 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 772
Thread: brucers GT/LET wip.
  1. #501
    23,813
    How close is the loom to the pedal? I'm really liking that.
  2. #502
    Norwich
    5,659
    Also, how did you manage to move your radiator over to more centre? I need to do the same in order to allow for the FMIC pipe work.
    See (http://www.pngclub.com/forum/showthr...big-block-nova) a few posts down
  3. #503
    Apr 2007
    Old Radnor, Powys
    2,803
    Do you remember what size hole you drilled to get the loom grommet to fit properly? Having the loom come out from that point... does it reach round to all the sensors ok?
    im not using the grommet, i made the hole elongated so i knew i could get the ecu plug through, then the rest is a squeeze through there. cant remember what size the hole is but i know the standard grommet needs a 60mm hole to fit. the only sensor off the top of my head that needs adding wire to is th amal valve, the coolant sensor is a stretch too.
    just drill new holes further across and voila. just be carfull you dont move it too far as the top hose wont fit correct otherwise.
    Its nice to check in here from time to time to see this getting better & better! Engine bay looks lurvely...
    comments like this i love!
    Quote Originally Posted by krobinson View Post
    Love this longtime!!!!
    why thank you!
    real close, as in i may have possible future problems. but time will tell.
  4. #504
    Apr 2007
    Old Radnor, Powys
    2,803
    update
    had a list of things i wanted to get done sunday just gone but everyting seemed to want to go wrong. sorting out the niggles this week before i go back this weekend.
    but, things i managed to get round to....
    stripped my old tailgate down so i could wire up my boot popper and fit the rear screen.
    only thing was the boot wasnt square so pulled down the rear of the headlining and messed about with that, once sorted i fitted my painted catch....
    it didnt want to lock correctly, so this week i had to modify it slightly and with a test on it tonight it works, hooray. so the popper will get wired up this weekend.
    i couldnt fit the rear screen as the rubber was rather dirty and has overspray on it. as all my cleaning kit was at home (12miles away) i had to leave the screen and take the rubber home.
    whilst fiddling with them bits i rigged up a system of filling up the gearbox, i didnt want to go buy a funnel. .
    bought some conduit to tidy up the engine loom, after getting it all on it looked so much neater and i started to like the bay again.
    double checked it still ran as may have disturbed something, it still does so result. it does idle a little high though. something else to sort out.
    moved onto the wipers, fortunately i had a pair of the smaller length wiper arms compared to what was fitted originally. there the same as whats on my red gte and ive got 19inch blades which also clear the lower part of the screen nicer.
    still a work in progess, the nearside arm reacts slower than the offside.
    put the rear bumper up ready to bolt up, i can only find one side bracket so i had to wait untill i went home and get another.
    another problem, the exhaust. i new it was coming out at an angle which is what i dont want so ive got to go back and get that modded.
    have also been fettling the front bumper for the intercooler, having to cut a bit at work then take it and try it is getting annoying but needs must.....here we have it up to sundays attempt.
    i have now cut some more off and its so close to fitting.
    thanks for looking
    bruce
  5. #505
    23,813
    Is looking great dude, wipers act just like mine.Everything looks great.
    How much room is there around the brake pedal with the loom in there? Any pics?
  6. #506
    Jul 2002
    8,107
    Looking good fella.
    Where the loom comes out looks a tad tight but seems to work. Much better than running it next to/over the battery.
  7. #507
    Senior User NOV4_SPORT's Avatar
    Dec 2005
    in front of the computer.
    3,033
    Very smart buddy, the car looks excellent, i really like the bumpers, keep up the epic work
    +rep
  8. #508
    Apr 2007
    Old Radnor, Powys
    2,803
    Quote Originally Posted by NOV4_SPORT View Post
    +rep
    thank you.
    i did reply to you last time, its very very tight. no pics atm sorry
    Looking good fella.
    yeh, helps to keep it neat and hidden
  9. #509
    m-teqbodyrepairs.co.uk Club Member 16v Nova Kev's Avatar
    Oct 2007
    dumbarton
    6,645
    thats fooking lovely.
  10. #510
    23,813
    Quote Originally Posted by brucer View Post
    Sorry i didn't see.
