Page 68 of 68 FirstFirst ... 1858666768
Results 671 to 679 of 679
Thread: Heated front screen
  1. #671
    Senior User Mark's Avatar
    Jul 2003
    Bristol
    7,443
    no worries fella.
  2. #672
    Gold Club Member# 001 Club Member Nova_Tek's Avatar
    Jul 2002
    Hertfordshire..... Builds: ......... Snowplough'd LET
    8,107
    Quick question.
    Does the sealer need to be applied to the inside of the rubber seal and then the screen slotted into the rubber or slot the screen into the rubber and then apply sealer under the rubber?
    Good chance the screen is going in tomorrow just need to know
  3. #673
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Yes^
    Has any one got there's wired up and working? As mine is and takes current from the battery but not 100% sure if its doing anything..
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
  4. #674
    Jul 2002
    8,107
    Yes, what? I wrote two different methods there.
    Mines not wired up just yet, was gonn ask actually.
    The screen has 4 wires. 2 on the left side of the glass and 2 on the right side. Is it one lot of wires earthed and the other 2 switched live?
  5. #675
    Senior User Welsh Dan's Avatar
    Feb 2006
    Sunny Wrexham Drives: Derv barge
    5,467
    The screens are divided into the left half and right half, which are isolated from one another. One from each side needs to be earthed, the other needs to be switched live. It doesn't matter which way around you do it top/bottom.
  6. #676
    Jul 2002
    8,107
    oh right got it. So for example: Left and right bottom wires to earths and the other two to the switch?
  7. #677
    Feb 2006
    5,467
    Yep.
  8. #678
    Jul 2002
    8,107
    Nice one
  9. #679
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Yes the rubber needs to be filled with sealant then the glass fitted,
    1 ground and one power each side.
    No one else got there's working tho?
    Far from suicidal
