Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 80
Thread: respraying, need many a tip!
  1. #11
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    From the factory there shouldn't* be any, and when refitting you don't need any, the rubber holds it in. But you can use a bonda yes.
    *Some do have it, but it might be dealer jobbies.
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
  2. #12
    If it ay bost dow fix it! Club Member Nobby's Avatar
    Jan 2005
    Brierley Hill West Mids
    6,341
    as said matey id do a 320 d a all over then a 500 then a 800 and then scotchbrite all over making sure you get in all the gaps and the before paint make sure theres no dust anywhere and as said use a decent preclean!
    " If you aint breaking you aint racing! "
  3. #13
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Why would you 500 after 320 it? (i 320 then 800)
    Far from suicidal
  4. #14
    Senior User AlexW's Avatar
    Jan 2008
    In Space, Lost.
    11,566
    Ive done that, makes it easyer to do the 800 imo
  5. #15
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    The 320 will do that...
    Far from suicidal
  6. #16
    Moo Motorsport
    Nov 2004
    Bolt-On
    4,901
    the scratches left by a 320 can be a little too harsh for some paints to cover.
    The 320, 500 800 is a common one, but im not sure if this lad is doing base and clear or 2k dg.
    If your doing 2kdg personally i would use 500's allround as opposed to 320's we used to use 320's on vans and if you look carefully you can see the 320 DA marks.
    usual course of action for me is
    80's any filler etc for repair work, 180s again said filler repair and surrounding area. 320's to feather out the 180's marks to stop it from sinking back.
    Primer over 320's Obv you will use red scotch for further feathering, we use 400's to flat the primer, followed by 800's grey wet scotch to clean, dry grey scotch followed by panel wipe mask then panel wipe then paint.
    Depending on the paint as said.. you can fook the 800's off you can also fook the 400's and 500's off if you want and just use a 320 and red scotch but thats only if your using 2k Direcgloss and you will need 2/3 good passes over the full car.
    Oh and dont forget to blow the bugger off after scotch and before panel wipe :D
  7. #17
    Jan 2005
    6,341
    Quote Originally Posted by Benn
    why not?? if hes got the time? keeps the scratches light ?
  8. #18
    Jun 2008
    yorkshire
    326
    500 will be ok even under silver,red scotch under primer and grey under colour unless it's a dark colour or direct gloss/solid colour then red will be ok,
    Don't waste time scotching over sanded areas only in bits that the sander can't get.
    Blow the car with air to remove crap like dust,dry dirt etc before panel wipe,(door shuts,engine bay,wheel arches etc)
  9. #19
    User G-nova's Avatar
    Mar 2009
    North Yorkshire
    1,435
    180 full car - primer full car - flat primer with 800 - spray colour and laquer - flat laquer with 1500/2000 and G3 then G10 Jobs a good one if you KEEP EVERY THING CLEAN!!!
  10. #20
    May 2007
    Cambridge/ Essex!
    2,501
    ok i dont get all this dk8 stuff?!? i dont even know what primer colour to use!?!? its going flame red (same as original) also i dont know how to take windows out, that link was very usefull, what paint~?!?! im guessing cellulose? gotta take doors off, dont know how to take windscreen out or rear screen AHHHHHHHH!!!!! its only next weekend aswel!!
