Results 1 to 10 of 10
Thread: ' proppah ' cambelt alignment
    Mar 2008
    SE London
    4,406
    Default ' proppah ' cambelt alignment
    for correct timing, does the crank have to be 'AT' tdc or 10 degrees before ?
    and just to make sure im half on the right track... TDC means the very peak of the pistons reach right ? now is it its peak on the upstroke, or its peak on the down, or the point right inbetween both where its at that point of inertia not mooving.
    doesnt say didly in the haynes manual about setting a belt, prety much says: " yeh, spark up a fag and have a coffee, take the belt off.. slap a new'un on, and roberts yer fathers brother ! "
    how many teeth out on the belt can a carb car run ?
    Senior User Welsh Dan's Avatar
    Sunny Wrexham Drives: Derv barge
    5,467
    The crank has to be AT the timing mark.
    No teeth out is how many out a carb car can run.
    TDC means piston 1 is at its absolute highest point.
    User Club Member
    Aug 2005
    next to the speakers
    1,318
    *jimbob* - sooo... where is the crank supposed to be for timing up the belt, as the marker on the crank pulley is at 10 degrees before TDC, another cm clockwise is TDC, unless my pulley is wrongly marked ?
    wish i had like £500 and could just put the fcuker into a garage and just say "sort the fcuking thing out please, its driving me nuts" *ching ching*
    edit : i suppose i could just slip it another tooth and see what its like, its pinking at mid to high revs at the mo, under load that is, tried a colourtune sparkplug on it too, and couldnt get a propper reading from it, not even with the mixture screw unwound as far as it would go, maybe ive got a problem carbside with feeding the fuel ?
    5,467
    djshaggeh, have you adjusted the dizzy timing?
    User Club Member
    Aug 2005
    1,318
    Sorry bit confusing, Jimbob was round here last night and posted this message on my account.
    I believe he has though and iirc he said that the engine speed changes but it doesnt stop his pinking, just moves it up and down the rev range.
    Mar 2008
    SE London
    4,406
    useless me mooving the dizzy tho dan, as i dont know where the cambelts supposed to be at, does no one on here know whether its supposed to be on TDC or the 10 degrees BTDC marker.
    5,467
    When I did my cambelt I lined both pulleys up with the timing marks. That was a 1.2 carb unit.
    Senior User mowgli's Avatar
    35,194
    what engine? cos if it is a 1200 or 1300 with a delco dizzy, then the advance/retard is probably knackered, causing bad ign timing.
    User Club Member
    Aug 2005
    1,318
    its 16sv
    Mar 2008
    SE London
    4,406
    with a 1.4sr ignition system on it
