Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: E/C16SE on bike carbs/webers, for and against.
  1. #31
    Sep 2006
    Nottingham
    1,802
    Wouldn't dream of disagreeing with you Craig, your'e entitled to your opinion, even if your'e wrong,
  2. #32
    Jan 2003
    SOMERSET
    19,510
    I didnt read any of the previous replies in the thread tbh.
    Its not like John doesn't know his stuff or needs telling what to do..
  3. #33
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Quote Originally Posted by tom reid
    I have a 16v inlet here waiting, dying to have a go at fitting/tuning one of these as I'll be using an x16 in the rallycar. I don't really believe that a RR is needed to tune, I run up the road with the wideband and tune where the engine needs it, might get more interesting when running megajolt.I'm having a few issues with fuelling just now, since i fitted the 290 deg cam, it's good throughout the rev band, getting a bit weak on full throttle and won't idle below 1500, very weak again, but I'll be playin later, I have a good idea that I'll need to put in a bigger needle jet, mess with the pilot jet and a few other bits, so still learning, but loving it!
    And whats the plan for ignition mapping/tweaks??
    You need rollers to hold the engine at a particular load/speed so you can map each table value to get the best ignition...?
    Fuelling is the easy bit with a wideband setup.
  4. #34
    Sep 2006
    Nottingham
    1,802
    Live mapping FTW, it's the future!
  5. #35
    Nov 2002
    Portugal
    216
    Hi guys and gals,
    After saw this topic, i'd like to ask a few questions as i'm planning to do this conversion on my Nova.
    My Nova has a hybrid C16SE conversion, i.e., block and head from a C16SE and the rest is from a C13SB so, its carb'd with the known "Auto-choke and pierburg carb"setup. Which carb models can be fitted? I'm looking for CBR600 carbs.
    Which procedures should i observe with ignition, fuelling, etc, to make the conversion running good and with a "economic" sight of the things?
    Waiting for your replies.
  6. #36
    Senior User phunkynova's Avatar
    Feb 2010
    Neuburg a.d. Donau. Bavaria D.E.
    1,571
    Quote Originally Posted by nuno_gt View Post
    Hi guys and gals,
    nuno I've sent you a P M
