Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Thread: Amp question.
  1. #11
    BASS JUNKIE
    Jul 2008
    christchurch
    747
    best bet would be to take the wires out and start again. had a similar problem in my fiesta and i just wired it again and it was fine. think my problem was the earth though
  2. #12
    Aug 2008
    Romford, Essex Drives: moredoor Loonage
    2,916
    that isnt what is bothering me too much, its that i need the engine running for the amp to work. do you think that fitting a bigger battery/alternator would solve this? or maybe a powercap?
  3. #13
    Feb 2009
    chesterfield
    1,659
    do what i said earlyer that will solve not needing your engine running to have your amp on. you shouldnt need a bigger battery or alternator if thats the only amp you are running. are the wires running down the same side?
  4. #14
    BASS JUNKIE
    Jul 2008
    christchurch
    747
    wouldnt have thought so. after reading through again i would say rewire the remote cable to the permanent live at the back of the stereo, that should sort most of it out
  5. #15
    Aug 2008
    2,916
    ok ill give it a go thanks, and no they arent running along the same side.
  6. #16
    Feb 2009
    chesterfield
    1,659
    just that causes interfrance some times when you first turn them on thats all if he uses the permanent live his amp will be on all the time even with the ignition off
  7. #17
    Aug 2008
    2,916
    the remote wire is meant to go to onto the blue wire on back of headunit isnt it?
  8. #18
    BASS JUNKIE
    Jul 2008
    christchurch
    747
    i had mine wired to permanent live and it was fine, just meant i didnt even need ignition on to listen to my music
  9. #19
    BASS JUNKIE
    Jul 2008
    christchurch
    747
    Quote Originally Posted by NovaBoi92
    yep usually
  10. #20
    Aug 2008
    2,916
    mine was wired on permamnent live. drained the battery constantly.
