Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 54
Thread: C16xe - Wire sensor !!!
  1. #21
    Senior User AlexW's Avatar
    Jan 2008
    In Space, Lost.
    11,566
    Quote Originally Posted by NOVABIKECARBED
    Yours running yet
    i have more chance of landing on the moon
    Its Still the same, waiting on another ECU.....
    Just to check with yours, does the plugs on the ecu match the loom ecu plugs (tis prob with mine)
  2. #22
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Everything else on mine is working and connected. Just the throttlebody is the balls up. Problem when you get parts given to you free I suppose
  3. #23
    Jan 2008
    In Space, Lost.
    11,566
    Would have thought it would bring up a ECU light but meh.
  4. #24
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Quote Originally Posted by AW06
    Well I would have thought that myself bearing in mind it wasn't plugged in
  5. #25
    Banned
    Jan 2006
    Hull, drives: The Wife's Celica, Fixes: Mates cars, Saves: for A16VTB
    11,720
    not till it runs matey...
  6. #26
    Nov 2003
    Austin, Tx, Usa
    24,200
    just to let you know, the c16xe and x16xe have the same TB's with the same sensors
    i fitted c16xe management to my x16xe, all i had to change was the knock sensor, ecu water temp, o2 sensor, on because the plug were diff
  7. #27
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Right as I had put this post up my mate has since put a x16xe throttle body on which has the tps
    Turned it over and ...
    ... Still the same, so tried flash codes again and it's now coming up with a 93 code. I'm pretty sure this is the finishing code??? Anyone help
    Is the way to reset the ecu's on these engines by unconnecting the battery and turning the ignition on and off 3 times?
  8. #28
    Nov 2003
    Austin, Tx, Usa
    24,200
    where about in West Yorkshire are you?
    mine has its mot next week, and fancy a road trip
  9. #29
    Jan 2008
    In Space, Lost.
    11,566
    Reset what? i belive you clear the codes by leaving the battery unpluged for a while.
  10. #30
    Nov 2003
    Austin, Tx, Usa
    24,200
    i left mine for approx 20mins, and the codes cleared
