-Coscast head, just had all new studs and got all new turbo manifold nuts for it. Has had new inlet manifold gasket and turbo manifold gasket. Also new one way valve fitted to small rocker cover breather pipe.
-Bottom end, has standard sized pistons, no lip on the top of the bore or scored bores, brand new bonded sump gasket.
-Turbo, with new downpipe fire ring and uncut standard downpipe.
-Loom, has had the 3 connector plugs in the car cut off where it was wired into a different car but other than that its perfect.
-All other ancilleries included consisting of ECU, AFM, boost pipes, standard intercooler, starter motor, alternator, dizzy.
Engine has been built back up with a brand new headgasket and cambelt. Initially stripped the head off after buying it to check condition etc before fitting it in my car.
Reason for sale is my shell is showing its age too much to fit this engine in so might as well let it get some use.
£1100
