In need of the knuckle that sits in between the steering column and the steering rack one of the pieces of metal is bend and causing a clicking noise when i turn the wheel price to inc P+P aswell please Karl...
Thats not what is making the clicking noise mate.
Did you use a hammer to take the wheel off ?
If so you have moved the collom down abit.
If you loosen off the 13mm nut at the bottom of the collom (bit by your feet) then move it back the wheel will then have more shaft.
Once moved up abit do the 13mm bolt back up.
Job done.
Failing that i mite have 1 of these but would have to check first.
If it is broken, I have a couple.
I had mine do this after it got broken into, but that was because the steering lock was trying to engage as I steered.
Have checked the above mentioned and it seems to fit in ok when i turn the wheel i can just feel it clicking ** it only does it a 1 certain point as you turn the wheel you can feel it click right down there i have just changed the column as i originally thought it was that thanks for all the replys Karl.
